Stub Pin Size?
Stub Pin Size?
'morning folks
n/s/r Stub pin has bugger all threads left and I need to replace both handbrake cables.  Had a quick look on line and found a chap on ebay that lists 3 and another site which sells a Group N part.  The problem is I've no idea what length pin is fitted to the car.
I looked on ServiceBox and that was no help. Also tried contacting the ebay seller as the listings stated 'email with reg' etc, but the chap then replies that he doesn't know & to check my original part!
As the pin is recessed I've no idea of how to measure it.
Car has drum brakes and matches exactly what ServiceBox says for the axle.
Does anyone have any idea what size pin would be fitted, or a method of measuring it?
knock it out and measure it
GTI6 Info
get down a breaker and get one from a drum beam, disc and abs drum are longer
ive some here if you need one. If you can measure it so i can be sure its the correct one.
Thanks guys,
The wife is moaning that she needs the car and doesn't have any leave left. I was hoping someone had a short cut to finding out the size. Looks like it'll have to wait a bit.
  Rear stub axle sizes weka 2 3,489 26-04-2019, 06:18 PM
Last Post: weka
  Gti 6 stub axel LironTurbo 3 2,957 14-08-2017, 08:53 PM
Last Post: cully
  Rear stub axle pin L95 4 3,884 21-06-2016, 07:07 PM
Last Post: L95
