air filter mounted on turbo?
Any one know if you can mount a air filter on the turbo at the back of the engine?
Afaik it would only be tiny so would call a big restriction
You could, but the MAF would be an issue, plus as already mentioned the chance of it being restrictive once you found one small enough.. Also it'd struggle for cold air down there.
  Gearbox Mounted Turbo TommiePuglet 22 15,547 06-10-2017, 06:15 AM
Last Post: TommiePuglet
  Gearbox mounted turbo mattgreene 32 18,427 04-06-2014, 12:55 PM
Last Post: toseland
