lucas pjmp leak
lucas pjmp leak
Hello, got a 1.9td with a Lucas pump, turned the fuelling up and now there's a diesel leak, it's coming from the black plastic plug you remove, took it off again today to check and its all fine with no cracks and the Oring around it is fine too. Any ideas anyone ?
Put a new 0 ring on it. Job done
(17-12-2014, 01:44 PM)bashbarnard Wrote: Put a new 0 ring on it. Job done
Just got a slightly bigger one and used some ptfe on it, primed up so I'll check it in a few mins see if its stopped,  need to put the Bosch one on it soon tho
Thanks btw
  Presumed Lucas Pump Leak ozpug 4 2,898 10-09-2015, 12:28 PM
Last Post: pioneer DJ paddy
  Leak of Pipe Air Leak PaddyPug 5 4,948 18-09-2013, 08:31 AM
Last Post: PaddyPug
