Head set...for other gaskets and seals etc
Coolant perhaps
Engine oil/filter
Check ya aux belt too...maybe worth doing
Threads: 186
38
Car Model/Spec: MG ZR VVC
hheeellllooooooo did someone say headgasket
Get it checked. If its not overheating and you remove it cold it should be fine though
Threads: 31
Car Model/Spec: tu5 bitza/cherry dt
Given 5 thank(s) in 5 post(s)
I'd take it to an engineers to have it checked my local one doesn't charge for checking just skimming
Threads: 28
Car Model/Spec: Anything but a 306
TBH those 8v TU's take a LOT of punishment, I've never NEEDED to get one skimmed, but if it's going to take some serious abuse it may be worth it.
I love these engines in these cars, I've managed a head gasket on one it 45 minutes before now (just ask Ruan!)
Matt-Rallye Wrote:Norledge for prime minister.
Poodle Wrote:I reckon Norledge has got it on the head mind.
Matt-Rallye Wrote:Norledge gets my vote tbh.
Easiest head gasket change in the world...
But yeah, if it's been overheated badly it'll need a skim, if it's not overheated, you'll probably be OK!
Threads: 28
1. Unbolt exhaust manifold from head
2. Drain Coolant
3. Unplug Fuel Pipes/Wiring loom
4. Remove top Cambelt cover
5. Release cambelt tension
6. Undo headbolts
Literally that simple!
