Threads: 38
Car Model/Spec: Ph3 1.8 Meridian Green
I've bought a cherrybomb, but I'm unsure on ways to fit the thing! I have a few ideas but i just wondered if anyone had done one before and what you did? I'm gonna need extra pipe, flexi pipe and clamps and so on, but whats the simplest way?
1.9 diesel Phase 2 - scrapped
1.8 meridian Phase 3 - going strong!
Threads: 169
91
Flexi pipe?!
Cant you just chop the old box off, and weld the bomb in its place? If you were feeling tight, use the hangers off the original box, or if not, put some new ones on...
Threads: 34
8
Given 8 thank(s) in 8 post(s)
I cut the flange off the standard box, welded that to my cherry bomb and put it on as a standard box, easier to remove if I wanted to lol
Threads: 16
Car Model/Spec: 306 GTI 3.0 V6
Man I bet that will be loud with a cherry bomb fitted! Not seen.or heard of one for many many years
Threads: 38
Cherrybomb is on, it's not too loud which is good! Spot on fitting too, cut off the flange, welded the reducer to the cherrybomb and then welded the flange to the other end of the reducer. Also made my own hangers so it looks like a backbox now!
