how to create new earth
Hi guys one of the earths on the inner ns arch is juat spinning the bolt wont tighten or come out.
If i cut the bolt to release the wires how would i go about making a new earth?
[Image: 20gh7o0.jpg]
Just grind back to clean steel. Drill a hole where you cab get a nut on the other side and coat everything with copperslip.
With it being on the inner arch though you cant get a nut on the other side
Just find another bolt the same sort if size, clean the metal up and use that.
I'm in the process of upgrading all the earths on the rx8
one word - Rivnut Smile
Project: Formula Peugeot
If it's the one by the ecu there is a second one in the same area.
[Image: sig.jpg]
  Earth locations pug306driver 2 3,394 22-01-2022, 04:19 PM
Last Post: pug306driver
Rainbow Gearbox earth connection part FIXED Welshy_Pete 7 5,340 22-05-2016, 06:29 PM
Last Post: P-Courty
  l/h/side earth point pug306driver 2 2,497 15-02-2016, 06:16 PM
