diesel fuel pump questions.
So haveing a conversation with a friend yesterday and got talking about the fuel pump in his vectra being on its way out and i wonder if its possible to fit a modified 306dt pump on it?
if it is then might end up doing that rather than spending £600 on a new one.
cheers Daniel
when in doubt...... flat out.
Depends on the injection systems. The vectra is more than likely CR, but even then the mounting points might be different, same as the pulley or whatever type of drive it has...
Theres lots of scrapped Vectras about, why not just get a 2nd hand pump from one of them. Confused
No, is the short answer.
  DIESEL PUMP SWAP? NOSE 3 2,201 13-10-2014, 12:37 PM
Last Post: NOSE
  SRowells diesel related questions! Eeyore 20 9,707 10-11-2012, 07:46 PM
