fitting 8.25 to 306GTI
Hello.. i have 306 gti6 and im looking for some set of new wheels
XXR 521 16x8.25 4x108 is my choice..
but i think that front will be okey with 195/45 ET0
in the rear i would like to have ET - 10 .. spacer is need for me
is possible to stick there ET - 5??
thank you for your time.
RichardAngel
Whats the ride height? Ive got 15x8 et-20 on my estate with 100mm drop. Needed to have the arch pulled alot to squeeze them in and had to run 185/45 tyres on the rear.
Use willtheyfit.com. put in what wheel specs you have at the moment and then the new wheel specs and it will tell you how much more poke etc you will have. Then measure it up on the car
[Image: 20gh7o0.jpg]
80mm drop front 95 mm rear..
can you send me photo with ET -20 and original arches? just pulled and rolled?
Theyre pulled alot. And the door shuts had to be re welded, and the corner of the door flaired a bit. But thats because its a 5 door. You may not have those problems.
Pics in here
http://306oc.co.uk/forum/thread-4281.html
Its quite a suttle flair considering how much its pulled.
okey thank you.. in rear i would like to have ET0 max.. in front ET10 .. it is possible to cut 10mm from wheel on machine? sorry for the expression but im not from english speaking countrySmile
