01-03-2012, 12:03 PM
I'm trying to sort the timing on a xsara 1.4i and cant find the flywheel locking hole for the life of me, anyone got amy ideas..? Cheers
Any citroen 1.4i owners...
01-03-2012, 12:07 PM
Tried behind the starter motor? I think thats where they are on most PSA engines...
01-03-2012, 12:11 PM
That'd have been my guess too^^
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
01-03-2012, 02:38 PM
Starter motor is on the back of the block on this one, anything that's not obscured by the motor is just open to the flywheel...
There's 3 holes that could be it on the front of the block, one large and two small. There's nothing on the flywheel that matches up to the larger hole - can see it quite easily - and as far as i can tell it's the same with the smaller ones too. I tried keeping pressure on a 5mm allen key in both holes while turning the engine over and didn't get anywhere, turned it over 3 times for each hole just to make sure, but nothing. WTAF?? :x
01-03-2012, 02:44 PM
![]() 5+6 are the locking pins, looks like it should be on the flywheel to me 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
01-03-2012, 06:33 PM
Farking legend, nice one mate cheers.
01-03-2012, 06:35 PM
Some of the early flywheels just have an indent rather than a hole.
01-03-2012, 09:26 PM
Sorted, got the missus to turn it over while i was looking for the hole, found the bugger eventually. Damn thing was exactly the same size as the allen key i was trying to find it with, slightly the wrong angle and it skated past, which at least explains why i couldn't work it out earlier. :roll:
Cheers for the help dudes, Connor you've got some rep reserved for when Scott and Foobs get their shizzle sorted.
01-03-2012, 10:28 PM
Oh yeah, getting your missis to help find the hole....bet she does that alot...
![]() 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
02-03-2012, 07:05 AM
Only if she doesn't want a surprise...
