Is it necessary? Power steering cooling
The sedan took a bit of a bump in its life to the lower cross member and the power steering cooling pipe took a pretty good knock, and has leaked all the fluid out of the system
Im planning on doing an electric power steering conversion, inc removing the power steering pump off the engine
Is the cooling pipe really needed? Or can i just sack it off and go for shorter pipes when i figure out where to mount the electric PS pump?
Its the thing resting on the towel:
[Image: 558672_10153430679095062_910536288_n.jpg]
The XS models and below didn't come with one, so its not necessary.
I know my 1.4 vivant didnt have one, ah well, cheers Smile
Nope sack it off!
  Power Steering Pump, All The Same? bigcheez2k3 14 10,468 20-11-2020, 11:28 AM
Last Post: vento85
  Power steering rack.....replacement options Jellomanpie 9 8,359 30-04-2020, 05:54 PM
Last Post: Mighty306
  Power Sterering Ram/ Steering damper pugfrank 6 6,263 08-11-2019, 01:47 PM
Last Post: pugfrank
