25-02-2012, 07:04 PM
Im in need of a disc rear beam as mines fu**ed. One that has good bearings and no camber. Not bothered wheather its lowered or standard height.
WANTED Gti6/Xsara vts rear beam
25-02-2012, 07:20 PM
Is yours that bad that you need another? You will probably be better off rebuilding your own. At least it will be right as rain afterwards.
You could end up with one that looks fine but fails soon after purchase? IIRC there is a company that rebuilds beams fairly cheaply. They will send you one out fully rebuilt and they collect yours. TEAM TRACK CAR + An E60 530d M-Sport for the daily
25-02-2012, 07:22 PM
Kris B had one last time I seen him post
26-02-2012, 12:49 AM
i did pm him over on .net but no reply as of yet.
Ian on one of my traling arms there is alot of surface rust and marks of the bearing was so i thought this would just be a better way to go and also this rear axle is off of a ph1 xsi so i will benefit in bigger torsion bars and ARB's
27-02-2012, 11:09 PM
anyone?
| Wanted Engine ECU GTI6 R Reg unlocked | KevinTW | 3 | 2,746 |
15-01-2020, 06:16 PM Last Post: Mighty306 |
| gti6 rear arb | Teddy | 0 | 1,507 |
23-07-2017, 07:23 PM Last Post: Teddy |
| Wanted GTI6 standard airbox. | KevinTW | 12 | 6,049 |
21-04-2017, 02:44 PM Last Post: Midnightclub |
