Threads: 266
18
Car Model/Spec: 205 DTurbo
Wheres the best place to tap into a TD04 for a EGT probe? Might get it done whilst its out of the car?
Also, it will only ever be a cheap probe so probably gonna melt anyway!
Threads: 90
Right before the turbo or you might as well not bother, ive used cheap nasty ones before without any problems, should be fine
Threads: 266
18
(30-04-2013, 08:18 PM)darrenjlobb Wrote: Right before the turbo or you might as well not bother, ive used cheap nasty ones before without any problems, should be fine
So... in the exhaust manifold or?
Feel free to help suggest a cheapo one off eBay for me!
http://www.ebay.co.uk/itm/180995416661 ?
Threads: 19
Car Model/Spec: Ph1 D-turbo(on going project)
Id say easiest place would be in the exhaust manifold where egr used to be..
Threads: 119
Car Model/Spec: MG ZS180
(30-04-2013, 08:33 PM)sweeney1987 Wrote: Id say easiest place would be in the exhaust manifold where egr used to be..
Also one of the worst places..
Threads: 90
The EGR is on its own passage in the exhaust, so wont see any gas flow / VERY un accurate reading!
Threads: 266
18
The one i linked any good? Goes up to 1,200*c.
Threads: 119
Buy my EGT gauge and probe if you want?
Threads: 127
33
Car Model/Spec: ZX Volcane TD
drill and tap bottom of mani if you want, nearest turbo
ebay might be ok, but a risk if it decided to let go and your turbo eats it
I've got a stack one which is lovely and an autometer one which is also lovely (and for sale haha)
pics of my egt locating on a T25 in the collector are in this thread if that helps
http://306oc.co.uk/forum/thread-2137-page-2.html
Threads: 198
135
On the exhaust mani, drill and tap as close to where the runners converge as possible and get the probe pointing right in the centre of the collector...
Threads: 110
20
(30-04-2013, 09:06 PM)Ricky Wrote: Buy my EGT gauge and probe if you want?
What 1 you got ricky? Price?
Threads: 266
18
30-04-2013, 10:59 PM
(This post was last modified: 30-04-2013, 10:59 PM by silverzx.)
So where I've circled the red ring?
Ideally would prefer not to touch turbo for obvious reasons (I don't want a hole in it in case I remove the EGT).
Threads: 110
20
I've put a EGT gauge on my d turbo and now need to get the probe fitted. Where is the best place to get it fitted? Like siverzx said I don't really to be drilling in to my turbo. Any help much appreciated
Threads: 87
48
come on who's got what for sale then? i'm after one too . .
Threads: 110
20
