Quick question
Quick question
Mate has a 2.1 406 apparently his pump keeps coming loose
He tightened it himself now it's got chronic blue smoke.
Would this be caused by retarding the pump or advancing too far?
At first I said turbo seals until he told me about the pump
Sorry for how this is typed first time using forums on an iPhone
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
blue smoke is normally more oil burn...black usually points to unburnt fuel
worth doing visual of the pump...you should be able to see if the pump has moved from original position or not.
Play a little with the timing and see if the blue smooke clears.
  Quick Fuel Pump Question lazareth1 5 3,168 28-07-2013, 10:37 AM
Last Post: lazareth1
  Another quick td04 question for who knows :) scottbmxer 8 4,887 19-07-2013, 05:38 PM
Last Post: scottbmxer
  Quick td04 question scottbmxer 30 16,139 09-05-2013, 06:14 PM
Last Post: Tom
