Central locking not working
As above it hasn't worked since I had the car not even when turning the key in the lock anyone got any ideas ?
fuse and or door loom?
as per your other post about wiring issues...check the looms.
fuse check is free too....
failing that, the servo motor in drivers door could also be at fault
Any idea which fuse is for the central locking I ain't got a handbook or manual
check them all as you got other issues too....or google it
Ill give it a google
In case it's of any use to anyone else
http://www.peugeotlogic.com/fuses/fuses3...elist6.htm
  Central locking/deadlocking/immobiliser going beserk. pug306driver 5 6,313 29-01-2022, 09:29 PM
Last Post: pug306driver
  central locking bypass auto unlocking andyw 1 3,738 04-07-2021, 03:58 PM
Last Post: Mighty306
  Universal remote central locking carrot 1 4,250 19-02-2021, 07:58 AM
