Car Model/Spec: 1.9 Non turbo estate
I swapped the door on a mondeo to help with the weight I got a piece of 2x2 cut a v in it with a saw and placed that on a trolley jack with a couple of cable ties and put that at the far end of the door
if the door ever arrives, its quite simple. Unbolt the check strap (do not push it into the door), knock the lock ring for the loom round (easiest to use a flat head and tap it round with your palm) and then undo the bolts. Make sure someones there to bear the weight as they are heavy and will easily damage your wing if allowed to swing into it.
Threads: 82
14
Car Model/Spec: P0XY Ph2 Dtub 5dr
18-10-2012, 10:12 PM
(This post was last modified: 18-10-2012, 10:12 PM by ash240970.)
Doors are easy as said - so far I've done 4 but a tip I will give you if you are doing it on your own is protect your paintwork with lots of masking tape around key areas such as sills/skirts
And the leading edge of the new door and the wing where it folds over as its very easy to chip or scratch the paintwork as they can be heavy as has already been mentioned but also awkward.
Threads: 92
43
The hardest part of this job will be receiving the correct part...
Threads: 236
36
Sounds fun.
Scott I may take you up on that offer, so you may live to regret it!
Have people had problems with this chap before then? I can vouch for him, I bought a whole bumper for my Focus after an accident with a wall, he was slow to post but this was more down to posting everything out at once, I received the item spot-on after about 10 days.
And he does have a phone number so is available if you need him too.
he just lied to me about when he was posting my stuff. took two weeks for a master cylinder to arrive.
Its easier to leave the 'blocks' bolted to the car and remove the hinge bolts iirc (I think it was the 306, might not have been though!) as the alignment is still there.
Threads: 92
43
Yeah 2 10mm bolts that go up through the hinges, but that doesn't mean it'll line up, as the 2 halfs of the hinges will have been aligned for 2 different cars
Threads: 252
7
I have changed 3 doors front and rears and they all light up perfect by just undoing the bolts top and bottom of the hinge and lifting the door off. Leave they bodyside part of the hindge attached to the car! 10 min job
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
