Threads: 448
51
Air vents either side? Or fiberglass them to a pillars
Why would you want more tweeters if you already have them?
Threads: 63
26
Car Model/Spec: GTi6
Cut a hole in the door card!
21
my mate has a e350 merc and he has some behind the front seats in the rear door cards. sounds awsome and i will be doing this when money lets me.
21
03-07-2012, 06:20 PM
(This post was last modified: 03-07-2012, 06:21 PM by kingy.)
componants will always sound better than a 2 way coaxle speaker so if your going for sound quality this is by far the best way forward. imo you dont need to fill your car with a million amps and speakers for it to sound good. the answer is to buy quality gear and to do it properly. ive heared systems that sound awsome and pulled over 150db with only one amp.
so many ways you can do it and it can get very complicated when you start looking at running parallel and running at 2 ohms. or even 1ohm.
sound deadening is another way to get your system louder. the less your pannels vibrate the more you can turn it up.
