sorry....another offset question
Hi, would et29 offset (7x16rim) with 10mm spacers cause rubbing issues on the inner arch or suspension? or would i need a larger spacer?
thanks
Use willtheyfit.com to visually see the difference between your existing setup and new one.
Cyclones are ET18 aren't they? So there'll only be 1mm difference with your setup...
(03-08-2018, 09:26 AM)Toms306 Wrote: Cyclones are ET18 aren't they?  So there'll only be 1mm difference with your setup...
Except cyclones are 6J aren't they? So it'll probably only be 1mm closer to strut tower but 1" closer to the arch (if i'm getting this the right way round)
thanks for that link Midnightclub, according to the site it will sit closer to the inner arch but with a spacer it should be fine, if not very close.
  Wheels offset arooscroocked 1 2,630 24-07-2018, 05:56 PM
Last Post: Poodle
  borbet offset tysonbully2k12 1 2,133 26-09-2014, 06:41 PM
Last Post: Toms306
Thumbs Down offset willJspears 16 7,409 11-01-2014, 12:39 AM
Last Post: Kezzieboy
