HP pump spacer
HP pump spacer
How much of an issue would it be if spacer number 9 was missing?
I've got a feeling it might have been missed when I had the pump replaced under warranty years back.
[Image: HP%20pump_zpsjn0eb4cg.jpg]
I found the spacer when I replaced the alternator.
Clearly not much of an issue if it's still all working fine several years later. lol
I thought it might be causing the belt too tight sound because of the pump being out of alignment, if it is with the missing spacer?
Sent from my Nexus 4 using Tapatalk
Looking at the drawing it looks like it would push the pump further to the right (as u look into engine bay) Which would move the pulley across to the right as well?
