Poll: ARB/P Bushes
You do not have permission to vote in this poll.
Fit GTI6 ARB
50.00%
1 50.00%
Dont, fit berlingo P bushes
0%
0 0%
Fit both
50.00%
1 50.00%
Total 2 vote(s) 100%
* You voted for this item. [Show Results]
Matching GTI front with rear
So guys, bought a fully refurbed GTI6 axle with solid mounts for a bargain price yesterday, got the GTI6 front arb too, is it worth having this fitted to my HDI too or will it not make much of a difference?
Currently has sachs shocks and springs on the front. Was either thinking of fitting bigger ARB or buying some berlingo p bushes.
I'd leave the front arb, stock 24mm rear works well too tbh.
bushes are worth doing, if needed, I wouldnt bother unless youre are worn out though.
So stock HDI 19mm ARB on the front with 24mm on the rear, will it not feel too soft on the front compared to the rear? Especially with the GTI one being 21mm? Cheers!
if you want understeer then fit the gti front arb other wise leave alone, i know afew gti6 that have fitted poverty spec front bars for this very reason
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Nice one, thanks guys, will leave on the standard front HDI GLX ARB and have GTI6 axle with solid mounts on the back Smile cant wait to get it fitted tomorrow and feel the difference!
you have less weight up front, so itll work fine.
  New Disks and Pads - Front & Rear Recommendations MisterGTR 6 4,170 10-09-2016, 08:15 AM
Last Post: cully
  Disconnecting rear brake lines at the front Iaitoo 21 11,126 04-06-2016, 08:22 AM
Last Post: pug306driver
  GTI6 rear beam and front legs Frankwood 1 2,048 10-05-2016, 08:09 PM
Last Post: Mattcheese31
