Threads: 66
Car Model/Spec: 306 hdi Dturbo
evening all, i have a leak, its on the drivers side door somewhere? i have removed door rubbers and re seated them but i still keep getting a pool of water behind the drivers seat, my car does not have a sunroof and im becoming frustrated at the leak as i cant cure it.....
anyone got any tips or advice on a cure?
Threads: 145
I'm still very much a tyro on these cars, and have a water ingress on the passenger side, coming thru the speaker due to the inner "Seal" plastic sheet problem, which has yet to be fixed.
Can you see any water on the door seal, maybe the inner seal on the door is leaking?
I have asked and been told that that the estate rear wash feed pipe runs along the drivers side, up the front pillar and along the roof channel area?
