19-09-2015, 10:04 AM
As above, what's the torque setting for theĀ 32mm bolt that holds the rear drum / hub / bearing whatever you want to call it please
Rear drum / hub torque setting
19-09-2015, 12:05 PM
On autodata it says a 306 is 185nm but I see you got a 405? It say 275nm for a 405 for some reason its different to a 306
19-09-2015, 12:11 PM
No it's for the wife's car which is a 306. Done to 200nm in the end. Doubt it will come off lol. Thanks though
19-09-2015, 02:44 PM
FT..../thread
![]() You have staked them into the groove though haven't you?
| Rear Drum Bearing Thrust Washer Problem? | Toms306 | 23 | 11,570 |
19-06-2014, 06:44 PM Last Post: Toms306 |
| Gti6 brakes on front, drum on rear | MarkHam | 5 | 3,848 |
13-04-2014, 10:54 PM Last Post: Mattcheese31 |
| 306 HDI Rear Disc Brake to Drum Brake Setup Switch | MY95 | 18 | 11,913 |
01-01-2014, 09:34 PM Last Post: MY95 |
