Wanted: XUD Power Steering Unit & Pulley (FCS Collection)
Lightbulb
Anyone have one they don't need/want they can post to me?
My one seems to have an extra large pulley held on with four allen key bolts which isn't the same as others I've seen.
Please let me know!
Many thanks!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
BUMP.
S14 Zenki Build
BUMP.
S14 Zenki Build
BUMP, looking for one posted now.
S14 Zenki Build
I have the one ive removed from my donor engine, i can send you a few pics if you like to see if its what you need
I have two here, both different.
One of them the inlet (low pressure) pipe bends away from the pulley, the other has a straight pipe about two inches long.
What diameter pulley have you?
(14-06-2014, 11:34 PM)205steve Wrote: I have the one ive removed from my donor engine, i can send you a few pics if you like to see if its what you need
Please mate, I'll PM you in case you don't see this.
(15-06-2014, 11:42 AM)Alex Wrote: I have two here, both different.
Uhh, I won't be able to check until Fri evening, one had four allen head bolts holding the pulley on, the other didn't if that helps?
S14 Zenki Build
  Wanted: Power Steering Pump Mighty306 0 2,222 03-02-2019, 11:24 AM
Last Post: Mighty306
  Power steering belt guard DeeTurbo 14 8,510 21-07-2016, 09:52 PM
Last Post: JamesG
  Power steering pipe Frosty 1 2,285 11-10-2015, 05:13 PM
Last Post: Frosty
