Threads: 374
38
Car Model/Spec: GTI 6
306 meet on the Isle of Wight!
consisted of me having a look at toms car as apparently he just had 2 new shocks installed by halfrauds and now having a "knock" turns out, i think, it's just a settling shock. It's not a hitting knock, more of a hissing knock if that makes sense...
anywho... then went on to take apart my coilies and top mount to correct a shitty clunking i had - sorted i THINK and ended up needed a new track rod end as inevitably the old one had f*cked up and started spinning in itself, tried EVERY way to get a bolt back on, wasn't having any of it.
The talent:
"This adds an extra 50bhp" ..
The meet...
AND seeing as this was the first, it was also a record for the meet! Well dont to everyone that attended! :clap:
Threads: 171
46
Threads: 374
38
oh
Threads: 5
Love it Ginge, keep it up!
Threads: 20
Car Model/Spec: Durbo
Double yellow. Oh dear.
teehee
81
can't believe I missed this meet! :-O
Threads: 150
14
Car Model/Spec: 306 HDI
great turnout boys keep it up!
306 HDI, soon to be XUD
Threads: 9
19
Given 3 thank(s) in 1 post(s)
to get the TRE back in i find putting the jack under the joint and jacking it until you compress the suspension a bit puts enough pressure on the TRE to stop it turning
Matty Wrote:Double yellow. Oh dear.
teehee
Parking fail!
Threads: 92
43
Should have said... Im always up for a meet
Threads: 374
38
mark_airey Wrote:to get the TRE back in i find putting the jack under the joint and jacking it until you compress the suspension a bit puts enough pressure on the TRE to stop it turning
did that, tried it out of the hub to try get the nut on alone... with a pair of mole grips, even then it was grinding itself into the grips
no bother to me...
Threads: 96
7
Car Model/Spec: 306 tractor
Connor Wrote:Should have said... Im always up for a meet
meet slaaaaag
Threads: 5
Couldn't have asked for a nicer day for it! Definitely first of many!
Threads: 202
58
Thumbs up car fwends!!
Threads: 5
Also, top marks for ginge, not many people put out on the first date...
Threads: 92
43
thms182 Wrote:Also, top marks for ginge, not many people put out on the first date...
Hes known for that
Threads: 5
Missed you today ginge
Threads: 374
38
Threads: 100
Could be a historic moment though. Might be the first pug meet where everyone who said they were coming actually turned up.
Threads: 5
Showing you guys how it's done :dance:
Threads: 171
46
Thats only because there is a grand total of 5 cars on that island
Threads: 13
did the police turn up to move you on , it looks wild
