26-01-2014, 10:56 PM
So this is the cooler I've got for my hdi but the core size is only 260x260x70. I will be using 2" pipework too. Big enough for stage 2?
[attachment=13103]
[attachment=13103]
![[Image: 20gh7o0.jpg]](http://i41.tinypic.com/20gh7o0.jpg)
is this cooler big enough?
[attachment=13103] ![]()
26-01-2014, 11:14 PM
Most people use 2.25 inch pipework. The intercooler is towards the small size of what people normally fit but I would have thought you would be fine with that. It should be easier to fit anyway!
26-01-2014, 11:17 PM
That's what I was thinking, small cooler, small pipework should be easier fitted. But would go bigger if I thought it would be an issue
26-01-2014, 11:46 PM
I would go bigger as realistically with the grille & bumper standard still there that will hardly get much airflow through it.
I would be inclined to go bigger tbh bud. Although it would do for the meantime and could be replaced if it became a problem with just a longer twin pass.
26-01-2014, 11:56 PM
You may be right mate, I will keep an eye out for other ones in the mean time
27-01-2014, 12:09 AM
Yep, big enough.
(well, assuming you mean for a stage 2 hdi)
27-01-2014, 06:31 AM
That's ideal, bigger won't make much more power, if any, it'll just add more lag. 2" pipework is plenty big enough for stage 2 as well.
27-01-2014, 11:20 AM
Cheers guys il plumb it in and see how it goes? Anyone have a link to what nipples I need for my boost gauge?
27-01-2014, 12:20 PM
get a brake bleed nipple off an old caliper, would do the job grand
27-01-2014, 12:37 PM
Cheers dude. The inlet elbow I have also has the egr port chopped off and welded so I will need to find a way to block the egr pipe. Will need a few blanking plates and some kind of end piece to bolt on
27-01-2014, 01:50 PM
Get the recirc valve tore off it and a plate on the exhaust manifold, if your inlet is welded make sure its air tight and your winning, just get it mapped out in your map.
27-01-2014, 05:12 PM
Engine off the mount and pull it forward with something and ull be sorted
