Torsion Bars/ARBs - Sizes and Sources
#31
(04-07-2014, 02:37 PM)welshpug Wrote: Indeed, with that response I would be particularly wary of anything they send out, mismatching trailing arms is not a clever idea!!
Are you after an axle for a 16v?
Yes mate. Not able to PM at moment as new member. Want to re-furb my rear beam but obv easier to get another and swap it- but want to be sure its the specific ZX 16v one!
#32
That will be tricky, however I might know of some...
#33
Ive had bad experience with IM axles...never did get my partial refund so will happily bad mouth them !!
[Image: sigi-2.png]
#34
http://pages.ebay.com/link/?nav=item.vie...06&alt=web
Seen these torsion bars on evilbay what's the chances they are actually 24mm..?
#35
That's an ARB not a torsion bar.
#36
Front anti -roll bar
Vehicle type Engine legislative type Anti-roll bar diameter
3 doors .......... KFX ..........................17
5 doors ........... KFX ......................... 17
3 doors ........ NFZ-WJZ-WJY ..............18
5 doors ....... NFZ-WJZ-WJY-NFT ............ 18
cabriolet ..... NFZ-NFT-LFY-RFV ............... 18
3 doors ............ RHY ........................... 19
4 doors .......... KFX-NFZ-NFT ................ 19
5 doors ............... RHY .........................19
5 doors ....... LFY-KFX-NFT-NFZ ..............19
4 doors ........ WJZ-WJY-RHY-LFY ............. 20
5 doors ............ WJY-RFV .........................20
Enterprise ......... WJZ-WJY ........................21
3 doors ................LFY ..............................21
5 doors ..............LFY-RFV ......................21
estate ....................WJZ-RHY ...................... 21
rear suspension
Data : Torsion bars
Vehicle type Engine legislative type tyres Torsion bar
3 and 5 door ...................KFX 165/70 R13 18,7
3 and 5 door .................. KFX 175/70 R13 18,7
4 doors .........................KFX 165/70 R13 19,3
4 doors ........... KFX-NFZ-DJY-WJZ 175/70 R13 19,3
4 doors ........NFZ-DJY-WJZ-LFZ-LFY 185/65 R14 19,3
3 and 5 door ............ NFZ-DJY-WJZ 175/70 R13 19,3
3 and 5 door ......... NFZ-DJY-WJZ-LFZ-LFY 185/65 R14 19,3
cabriolet .............................all models all models 19,3
Overseas export .................. all models all models 20
Affaire ............................all models all models 20
3 and 5 door ..........................KFX ( LPG ) 185/65 R14 20
3 and 5 door .........LFY-NFZ-RHY-RFV-RFS 195/55 R15 20
estate .......................KFX-NFZ-DJY-WJZ 175/70 R13 20
estate .................... NFZ-DJY-WJZ-LFZ-LFY 185/65 R14 20
4 doors ..................KFX ( LPG ) LFY ( LPG ) 185/65 R14 21
estate ................................KFX-WJZ-NFZ 185/65 R14 21
estate ........................... NFZ-RHY-LFY-RFV 195/55 R15 21
Data : Anti-roll bar
Vehicle type Engine legislative type Anti-roll bar (/)
3 and 5 door ........................ KFX 18
estate ................................. KFX 18
3 and 5 door ... WJZ-NFZ-LFY-LFZ-DJY 19
4 doors ........... KFX-DJY-LFZ-LFY-NFZ 19
estate ......................... RFV-LFY-NFZ 19
cabriolet .......................... all models 19
3 and 5 door .........RHY-DHW-DHY-RFV 20
4 doors ........................ DHY-DHW-RFV 20
estate .......................................... RHY 20
Overseas export all models ; Excluding estate 20
4 doors .......................RHY-WJZ-LFY ( LPG ) 21
Grand export estate ................................... 21
estate ...................... LFZ-DJY-DHW-DHY-WJZ 21
3 and 5 door ....................................... RFS 24
Deteriorated road condition Reinforced suspension 24
#37
(21-09-2014, 02:14 PM)welshpug Wrote: That's an ARB not a torsion bar.
my bad Blush still one thing that confuses me is the rear beams!!
#38
Hi,
I own a citroen ZX volcane 1994.
I will be visiting the UK in a few weeks from now
looking for a shop to buy used/new(?) TB 21mm and ARB 24mm.
Can anyone suggest where I can buy these/order online?
I will be in the area of Hatfield.
thx Eyal
#39
Just out of curiosity what size are tb's and arb's in a phase 1 2.0 xsi?
#40
same as a gti6.
#41
Thanks, wasnt sure if the 8v engines had different tb/arb than the 16v models
#42
ok, so with many thanks to Jonny for letting me know how tired my car is, it is getting time to sort out the handling stuff Smile
i would like to stiffen the cabby just a little so it doesn't wallow into corners like a bus. how can i do this on the rear beam? front end is obv a different thread, and i have an idea of what to do there. but this is the first car i have ever had with an ARB. they have all been either solid beams, or leafers.
Not always Grumpy!!
306 Cabby SE, 2.0l 16v
#43
hi all are the arb n tb in a phase 3 xsi same as gti6 as above i am unsure thanks
#44
(26-02-2019, 08:48 AM)Quietone Wrote: hi all are the arb n tb in a phase 3 xsi same as gti6 as above i am unsure thanks
Yep.  20mm TB's & 24mm ARB.
  Stubborn torsion bars Mighty306 12 7,654 09-06-2017, 08:07 PM
Last Post: Mighty306
  Uprated torsion bars mossy1985 17 10,488 23-10-2014, 06:48 PM
Last Post: mossy1985
  Uprated front and rear arbs mossy1985 6 4,280 22-10-2014, 04:57 PM
