Ph1 starter motor relay box?
Hi everyone,
could someone tell me what the little black box is that's attached to the battery case and says bosch on it with two white wires attached and another bigger connector? The little box is buzzing like hell on mine when I turn the ignition on and won't let it fire up
 Black 306 1.9 dturbo PH1 - on going project
Moonstone 306 GTI6 PH2 - Stripped and Scrapped
Honda Civic EP3 preface lift type R - Write off/Stripped and scrapped
Diablo 306 1.9 dturbo PH3 - Scrapped
Honda Civic EP3 facelift type R - daily
That's the relay to the glow plugs. Got one here if you need one ,
How much posted dude?
£10 posted
It should still fire up just not very easily.
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
  Starter motor; XUD/XU10 ginge191 6 4,293 19-08-2013, 09:33 PM
Last Post: Rich306
  Starter motor spinning Kilifi 9 6,305 18-07-2013, 07:58 PM
Last Post: Kilifi
Exclamation Car won't start? Starter Motor? silverzx 12 6,863 19-02-2013, 01:00 PM
Last Post: silverzx
