Slam panel air feed
Wanted: Slam panel air feed
In after the air feed bits that bolts to the slam panel for a ph1 d turbo. Not sure if the ph2 are the same.
This is the bit in after
[Image: null_zps0323444f.jpg]
If I can collect at FCS that would be ideal
Get a petrol one which goes straight back rather than one that angles!
Sent from my iPhone using Tapatalk 2
Is it the same as the 1 in the pic cuz that's the 1 on my s16. Are you going FCS?
1.4 petrol style ones are straight
  Wanted: slam panel air intake Piggy 4 2,290 04-12-2014, 06:02 PM
Last Post: Piggy
  Wanted: ph1 slam panel ash23 4 2,252 07-03-2014, 09:10 PM
Last Post: HDIkyle
