14-07-2013, 07:11 AM
Right, this was going to be my project for Sunday, but since I got banned, I wrote it in Notepad and copied and pasted it over to here.
Okay, Common things to check before an MOT:
Lights
Dashboard instrument cluster lights
Airbag/pretensioner system
Indictators
Tyres
Brakes
Window washer fluid
Horn
Wipers
Suspension/steering components
Interior
Lights
Turn all the lights on, including indictators/hazard lights, foglights and number plate lights (should come on with your main lights).
Anything that indictates a safety problem shouldn't be on. Something like a service light isn't a safety critical item therefore it will not affect the outcome of the MOT.
Airbag System
The airbag system is a common failing point on 306s. If the light is flashing there is a problem with the pretensioners, if it is solid there is a problem with the airbag.
If you have either warning, I suggest you look underneath the seat and make sure that the orange plugs going to the pretensioners are securely connected.
Also remove the airbag from the steering wheel (two T20 torx screws at the back) and check that the airbag is correctly plugged in and the rotating squib is correctly seated.
If you have checked the above and the airbag light is still on, disconnect the battery, wait 10 minutes, unplug the airbag module and then replug it.
This will reset the device and all being well make the airbag light go out.
Tyres
All tyres should have sufficient tread which should be atleast 2mm (legal limit is 1.6mm) around the circumference of the tyre. Any bulges in the sidewall will cause a failure. If there is a screw or nail in the tread of the tyre it will lead to an advisory notice (get it sorted as soon as possible).
Generally sidewall damage is more serious than damage to the tread, so if there is a cut on the sidewall you could fail for it.
Brakes
Inspect brake hoses, brake pads and brake shoes.
A common reason for failure of rear drum braked models is the auto adjuster seizing up leading to the brake shoes being too far away from the surface of the drum. To rectify this, remove the drum from the axle and adjust the self adjuster (pictured) to bring the brake shoes closer to the surface of the drum.
You only need to adjust them a little bit at a time, put the drum back on and then see how it feels. They should be binding ever so slightly, so that if you spin the wheel it comes to a dead stop rather than just losing momentum gradually.
For the front brakes, you can remove a front road wheel from one side and check through the slot in the brake caliper. The inner pad will be more worn than the outer pad, this is normal as the inner pad is the one pushed by the piston and therefore has more force exerted on it.
If you have standard DT brakes and they fail even after a cleanup, it is probably as a result of worn calipers which should be replaced with the bigger HDi calipers and discs, as standard the DT is quite "underbraked" so it is not worth rebuilding the standard calipers.
For the brake hoses, slight deteriation of the outer surface of the hoses will result in an advisory, anything more will result in a failure.
Below are pictures of the drum and the adjuster mechanism:
![[Image: P1010042_zps1cedf9c3.jpg]](http://i145.photobucket.com/albums/r233/Flynn_bucket/Turbo%20project/MOT%20Checklist/P1010042_zps1cedf9c3.jpg)
![[Image: P1010044_zpsa82ec503.jpg]](http://i145.photobucket.com/albums/r233/Flynn_bucket/Turbo%20project/MOT%20Checklist/P1010044_zpsa82ec503.jpg)
Here is the slot in the brake calipers as mentioned:
![[Image: P1010040_zps4addf53f.jpg]](http://i145.photobucket.com/albums/r233/Flynn_bucket/Turbo%20project/MOT%20Checklist/P1010040_zps4addf53f.jpg)
Window Washer Bottle
This is a really easy one to check yet easy to forget as well. Make sure that the washer bottle has enough screen wash in it and that the correct dilution is present.
Horn
Test the horn to see that it is working. Note, there are two and if one is broken it will sound really pathetic and probably fail. This is a very simple electrical system, failing points are fuse (which would affect other things as well), instrument stalk, the plugs that plug into the horn(s) themselves, or the actual wiring loom (rare but a pain if it does).
Wipers
Check the rubber of the wipers, ensure that the wipers clean the screen effectively. New wipers can be bought cheaply, although beware of those costing 5 pounds as I bought a set and the metal rusted really quickly. Aim to spend 10-20 pounds for a decent set of wipers that will last. I currently have Bosch ones from Euro Parts and they still look as new after a year.
This is a common area for failure because the suspension and steering components have a lot of dust covers on them. If the covers break and allow entry of dirt then that can be a cause for failure. Steering arms can also be a cause for failure if there is excessive play due to wear of the bushes. Droplinks are another common point for failure, on cheap ones the bushes/dust covers wear out very quickly. They are cheap to buy and easy to replace, but it might be worth investing in some better quality ones depending on how long to choose to keep the car. Also make sure the dampers are not leaking and not allowing the car to bounce up and down excessively.
In some cases, even if dust covers are not broken, the ball joint will be so worn out that the grease inside will turn solid and lead to a notchy ball joint. You can check the ball joint by wiggling it from side to side. This is sometimes easier with the wheel on, you are looking for a notchy movement which is what a worn out ball joint will give.
This is the correct condition for the outside of a steering arm balljoint:
![[Image: P1010041_zpsd4987270.jpg]](http://i145.photobucket.com/albums/r233/Flynn_bucket/Turbo%20project/MOT%20Checklist/P1010041_zpsd4987270.jpg)
Interior
All seatbelts should be correctly functioning and in place. Pedal covers should not show excessive wear, seats should be secure, nothing (such as fluffy dice) should be hanging from the interior mirror.
Extra considerations for modded vehicles
If you are driving a gov modded XUD, be sure to restrict the throttle lever movement before the MOT so that the tester can't overrev the engine.
For those running coilover front suspension, make sure that they are at a reasonable height so that the car can be driven onto the lift.
For diesels, always have atleast one box in the exhaust system. This does not have to be a functional box but it is important to have a kind of box visable to the tester.
For tuned XUDs, consider reducing off boost fuelling for the duration of the test to reduce offboost smoke. Also consider running vegetable oil as the smoke is far less noticeable than diesel smoke.
Right that's all I can think of but other members feel free to contribute useful information in the thread. Thanks
Lights
Indictators
Tyres
Brakes
Window washer fluid
Horn
Wipers
Interior
Lights
Airbag System
Tyres
Brakes
Horn
Wipers
Interior
