Electric window switch help
(3 door dturbo) How can I make my drivers window 'one touch' there isn't the A thing on the switch so you have to hold the switch to go all the way down/up. Is it just a case of putting a 'one touch' switch panel to get them to work like that.
This is the switch I mean[Image: u3u4a8em.jpg]
NO SMOKE NO POKEBig Grin
no i believe the door loom is diferent and maybe other things
if you swap just the switch over it will blow fuses
(24-04-2013, 10:12 PM)cully Wrote: no i believe the door loom is diferent and maybe other things
Ah ok then. I noticed they have the mirror controls as well so would also need a pair of them so not worth it.
has anyone ever managed to get the one touch switch to work in place of the regular switch?
I'm just wondering what exactly needs to be changed.
  Removal of driver's side electric window switch balkan_bozo 10 9,051 04-07-2018, 03:03 PM
Last Post: pug306driver
  off side Electric window and door not working bluebenz1 1 3,359 01-05-2018, 10:07 AM
  Electric Window Help partybish 12 8,424 15-08-2017, 07:06 PM
Last Post: Poodle
