18-04-2013, 03:28 PM
As title after carrier bolts for my 266 brakes. Price posted please!
Wanted: XSi / HDi 266 Carrier Bolts
18-04-2013, 04:01 PM
You can get them from peugeot for like £2.something each.
18-04-2013, 04:28 PM
Ooh. Anyone have part number?
or chassis number for a HDi?
18-04-2013, 07:14 PM
Aren't all the carrier bolts the same?
(18-04-2013, 07:14 PM)Frosty Wrote: Aren't all the carrier bolts the same? 205's are longer than DT setup
Phaes 1 GTI 6 - Onyx Black
18-04-2013, 08:04 PM
Yeah. Ill have a look in scrapy when I'm next there. Does anyone know if 247 and 266 bolts are same?
18-04-2013, 08:21 PM
Pretty sure all 306 carrier bolts are the same. Some of the carriers are thicker than others so the treads in the hubs get a bit rusty and need cleaning so the bolt can go all the way through to go tight
18-04-2013, 09:17 PM
Handy to know. Ill see what I can scavenge.
18-04-2013, 10:37 PM
i'm braking a ph2 soft top 2L if the bits are the same/fit i don't mind taking them off and posting them mate
04-05-2013, 07:06 PM
(18-04-2013, 10:37 PM)maxlee Wrote: i'm braking a ph2 soft top 2L if the bits are the same/fit i don't mind taking them off and posting them mate Only just remembered about this, I got some 1.9DT ones which are hopefully okay. Just trying to talk someone into helping me fit them! Danny, Connor, Chris etc.
04-05-2013, 07:34 PM
No the bolts aren't the same, remember when we fitted those brakes on your DT?
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
04-05-2013, 09:06 PM
^^ exactly
04-05-2013, 10:38 PM
In that case I'm still after some! Cheers Connor.
04-05-2013, 11:24 PM
I fort that all the bolts are the same on 306 front brakes its just the fact that d turbo brake carriers are thicker that hdi/gti carriers so the treads in the hub get dirty and thats why the carrier does go tight sometime. Just need to clean the threads in the hub before hand
| gti6 carrier and slide pin | HDIkyle | 1 | 2,245 |
17-08-2017, 02:29 PM Last Post: humberas |
| Wanted: Caliper carrier bolts & abs sensor stuff | mcglynn | 7 | 3,888 |
31-10-2014, 09:06 PM Last Post: mcglynn |
| Wanted: NSF GTi-6 carrier and slider pin | Curt | 4 | 2,965 |
13-07-2014, 11:57 PM Last Post: Curt |
