Wanted: 306 11mm modded pump
Looking for built 306 11mm pump with gov mod and ground lda, that's been running for awhile, with no problems, money waiting
Pretty sure anton is selling Joes old one on here, theres a thread
[Image: sigi-2.png]
Yeah I mailed him, cheers
ive got a standard 9mm il gov mod it and gring lda pin if your intrested?
Think dum dum is stil sellin 11mm transit pump if u fancy the build
[Image: J5hxCcC.jpg]
(05-04-2013, 02:51 PM)CJ_Derv Wrote: Think dum dum is stil sellin 11mm transit pump if u fancy the build
Darren now has that. Tongue
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Cheers guys but am just after a built 11mm ATM,
Anyone?
If you have a 9mm pump....
I'll swap you?
Can have one built up for you, will be couple of weeks though you interested?
(12-04-2013, 08:21 PM)Piggy Wrote: If you have a 9mm pump....
I'll swap you?
I don't have a spare 9mm as iam going to keep it as a spare, also after a 11mm that's been used and tested
I have a 9mm with lines injectors and bracket exc. and a 11mm pump if you fancy building your own Wink
I'll swap you?
well Im driving on the 11mm!!!
  Wanted: bosch pump and transit 11mm pump spike2002 8 4,594 14-10-2014, 06:41 PM
Last Post: spike2002
  Wanted: 11mm bosch pump setup maffy 2 2,451 05-02-2014, 09:37 AM
Last Post: Piggy
Wink Wanted: 11mm Bosch pump 306pc 11 5,755 20-12-2013, 11:10 AM
Last Post: 306pc
