29-01-2012, 04:56 PM
I'll see if its long enough phill, the 406 pipe I've got keeps blowing off and hangs stupidly low.
![[Image: sig.jpg]](http://i89.photobucket.com/albums/k220/c_j_m/sig.jpg)
FAO Ginge191 - pipes
29-01-2012, 04:59 PM
Ok np. Ill send you one of the other 2. Still sealed in their bubble wrap lol
29-01-2012, 11:48 PM
Phil - a company can make it up for me with:
1 x 90deg silicone 57-51 reducer 1 x straight alloy coupler 1 x 90deg silicone 51mm bend you reckon there would be enough room for this?
29-01-2012, 11:52 PM
4WayDiablo Wrote:Chris Wrote:Phill, is that bend in the last pic a 90* and a 2.25" Might be the photo... but thats a funny looking 90 degrees... 306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
30-01-2012, 05:32 PM
ginge191 Wrote:Phil - a company can make it up for me with: Phillip?
30-01-2012, 06:02 PM
ginge191 Wrote:didnt see that there lmaoginge191 Wrote:Phil - a company can make it up for me with: my pipes are 57mm? am i missing something? ![]()
30-01-2012, 06:17 PM
im assuming that the 57-51mm is irrelevant which way it goes round??
30-01-2012, 06:23 PM
true but why is there another 51mm 90 bend? surely that should be a 57mm no?
30-01-2012, 06:33 PM
Im assuming the joiner pipe is 51mm? i shall enquire
30-01-2012, 06:47 PM
joiner pipe? so confused? so your going
51mm 90 / 51- 57mm 90 to make the u bend to send it gearboxwards? ![]()
30-01-2012, 07:05 PM
4WayDiablo Wrote:joiner pipe? so confused? so your going yes, and a joiner pipe to join the two 90* together... as 90 + 90 = 180 :geek: this is the only viable way to create a U bend from turbo at 51mm to piping at 57mm ![]()
30-01-2012, 07:42 PM
ginge191 Wrote:A 51mm u bend then 51 - 57 adapter then straight pipe?4WayDiablo Wrote:joiner pipe? so confused? so your going ![]()
30-01-2012, 07:46 PM
oui!
turbo -> 51mm 90* -> joiner pipe -> 51mm - 57mm 90* -> straight pipe....
30-01-2012, 08:04 PM
Or just get 1 x 180 bend 51mm then get a 51 - 57 adapter is what i was trying to say
30-01-2012, 08:06 PM
4WayDiablo Wrote:Or just get 1 x 180 bend 51mm then get a 51 - 57 adapter is what i was trying to say ohhhhhhhhhhhh i get you! that could make more sense i suppose, saves faffing around, id still need a joined pipe as i cant just pop two pieces of silicone together, right? unless you have some odd 51mm pipe? edit: 180* 51mm -> joiner pipe -> 51mm - 57mm http://www.ebay.co.uk/itm/Black-Silicon ... 1750wt_854 http://www.ebay.co.uk/itm/Alloy-hose-jo ... 1e603e356e http://www.ebay.co.uk/itm/SILICONE-NOME ... 3368b73e06
30-01-2012, 08:12 PM
They do solid pipe ones. Stainless 51 to 57. Then i have some 57 straight silicon perfect to join.
The third pic on the first post. The red pieces ![]()
30-01-2012, 08:23 PM
http://www.ebay.co.uk/itm/51mm-57mm-ALL ... 4aa785c660
BOOM! i'll crack on and order now! ![]() OH and i may need a 90* silicone piece to get round the engine??
30-01-2012, 08:27 PM
You said you would get that lol ive got stainless 90's we can cut down if you want...?
30-01-2012, 08:32 PM
4WayDiablo Wrote:You said you would get that lol ive got stainless 90's we can cut down if you want...? yeh i'm just ordering now so im re-affirming to myself, you can keep that intact mate ![]() I'll buy the 51mm ubend, metal adapter and 90degree silicone - should be plenty full!
