Clutch 'ratchet'? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Clutch 'ratchet'? (/showthread.php?tid=9902) |
Clutch 'ratchet'? - Seb_Ryan - 17-01-2013 Do they have them? My was being funny earlier, pedal was loose, then it crunched and it's dropped a fair bit.. Clutch still works fine RE: Clutch 'ratchet'? - Eeyore - 17-01-2013 if you mean an auto adjuster? then yeh they should have them. Wether they work or not is another matter! RE: Clutch 'ratchet'? - samass - 17-01-2013 give the pedal a few stamps, if that doesnt do anything, then push the pedal to floor, and let your toe slip off it so it springs back up, then try the biting point again, do that a few times to reset the adjuster |
