small petrol engine - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: small petrol engine (/showthread.php?tid=9618) |
small petrol engine - cully - 08-01-2013 ive had a 4 stroke generator in the shed for some time now that has always been a bastard to start (pull start) so i thought it was time to sort it or sling it out so ive stripped the engine down expecting to find worn rings causing low compresion but no it looks as if the head gasket has been leaking or the valves arnt sealing 100% so i maybe able to save it to live again fingers crossed so in going to give it all a good clean lap the valves in and lap the head together with the block and see if i can find a head gasket anyway people like pictures so heres a few of cam and govnor assembly crankshaft casing brake down assembly RE: small petrol engine - Matt - 08-01-2013 Awhh it's soo tiny RE: small petrol engine - Just Sean - 08-01-2013 looks like uve lost 3/4 of it! RE: small petrol engine - cully - 08-01-2013 (08-01-2013, 08:11 PM)Just Sean Wrote: looks like uve lost 3/4 of it! yup lost 3/4 pots and 6 of the valves ![]() but i could gov mod it as it runs restricted rpm to set the frequency of the alternator RE: small petrol engine - THE_Liam - 08-01-2013 Make a go-kart. RE: small petrol engine - procta - 08-01-2013 cully once its up and running give it a turbo and a stage2 |
