Tuning xud on veg.. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Tuning xud on veg.. (/showthread.php?tid=9276) |
Tuning xud on veg.. - RePT - 27-12-2012 Could i achieve a decent tune? Or is there any difference?(between veg and diesel tune) RE: Tuning xud on veg.. - ozonehostile - 27-12-2012 Still tune the pump and turbo the same for derv or veg, and unless you run pure derv then veg you wont necessarily notice much difference. diesel is higher octane than veg oil so if your after ultimate poer figures from your tuned xud, derv is the way to go, but if you want to lower the running costs but still have a bit of poke then 50/50 mix (in cold weather anyway) will be fine. just need regular fuel filter changes when running veg, again, especially in the cold as it does tend to clog up Tuning xud on veg.. - RePT - 27-12-2012 Cheers for that. Running full tank of veg +5ltr of unleaded right now. Guess ill wait till its empty and drop £10 diesel in! Then back to veg after ![]() |
