Boost on idle - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Boost on idle (/showthread.php?tid=9089) |
Boost on idle - Dum-Dum - 19-12-2012 Is there any issue with having boost on idle as long as it dosent start pushing the LDA pin? RE: Boost on idle - Tom - 19-12-2012 Wouldnt of thought so.. Surely your turbo can be set in such a way it wont be boosting on idle anyway? RE: Boost on idle - Dum-Dum - 19-12-2012 (19-12-2012, 09:45 PM)Tom Wrote: Wouldnt of thought so.. Surely your turbo can be set in such a way it wont be boosting on idle anyway? Yeah definitely but its just easier not to bother and have boost on idle. RE: Boost on idle - Bananalad - 19-12-2012 Whistle on idle is win RE: Boost on idle - n0v0s - 19-12-2012 I would have thought the boost generated be quite negligible at idle (if you're on about a vnt). A supercharger on the other hand would probably register a few psi. Don't think it would cause you any problems. Adjust preload /fit stronger spring and it should be fine. Also, whistle on idle does not = boost!! Re: Boost on idle - Dan! - 19-12-2012 Wouldn't matter if it dropped the lda pin anyway as the lda lever doesn't do anything until the throttle arm is moved. RE: Boost on idle - Bananalad - 19-12-2012 I know, mine doesn't boost on idle but it whistles, i just presumed the whistle would be louder RE: Boost on idle - darrenjlobb - 19-12-2012 other than raping the turbo for no reason, no harm...but if its boosting on idle, sounds like if its a vnt you have the vanes stop wayy to far out...unless we are talking superchargers here |
