Ph1 and ph3 doors - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Ph1 and ph3 doors (/showthread.php?tid=850) |
Ph1 and ph3 doors - Matt - 11-01-2012 Are the the same? Other than the rubstrips? Re: Ph1 and ph3 doors - springs - 11-01-2012 No. The door card mounts are different but can be changed to fit Re: Ph1 and ph3 doors - Connor - 11-01-2012 Rubstrips have the same holes, as springs said, only difference is how the door cars mount. Not that you can get moonstone in Ph1
Ph1 and ph3 doors - Matt - 11-01-2012 My friend has ph1 sigma doors, with s16 door cards, which I planned on fitting to mine, but as I may have broke my drivers door today, just going to spray the ph1 doors and fit them lol Re: Ph1 and ph3 doors - Ed Doe - 11-01-2012 1. how did you break the door? 2. arent the rubstrip indents taller as the ph1 trim is taller? Re: Ph1 and ph3 doors - Connor - 11-01-2012 Yes the trim is very different, but the holes are the same (except the wings, see pics of my Ph1.3 to prove this...) Re: Ph1 and ph3 doors - puglove - 11-01-2012 basicaly yes, with the door you already as a donner it can be done very easily Re: Ph1 and ph3 doors - cwspellowe - 11-01-2012 Connor Wrote:Yes the trim is very different, but the holes are the same (except the wings, see pics of my Ph1.3 to prove this...) +1 Superglue ftw
Re: Ph1 and ph3 doors - ginge191 - 11-01-2012 arn't the rub strips width different dependent on the model - i know between my 1.4 and dturbo they were different... Re: Ph1 and ph3 doors - darrenjlobb - 11-01-2012 Door panels are identical regardless of rub strips, only change as said is the mounts, but 5 mins job to change with drill and rivots
Re: Ph1 and ph3 doors - ginge191 - 11-01-2012 darrenjlobb Wrote:Door panels are identical regardless of rub strips, only change as said is the mounts, but 5 mins job to change with drill and rivots hm weird why my strips were different? :think: i might get a pic of it... i thought they were the same until phil (4waydiablo) pointed it out to me i think, up at cheddar. Re: Ph1 and ph3 doors - Connor - 11-01-2012 The actual trims are different ginge, but the holes they go into are not Ph1 and ph3 doors - Matt - 11-01-2012 darrenjlobb Wrote:Door panels are identical regardless of rub strips, only change as said is the mounts, but 5 mins job to change with drill and rivots Mounts inside or out? Door card or sidestrips? If its the door card I don't mind as I'll use ph1 door cards lol Re: Ph1 and ph3 doors - Connor - 11-01-2012 Are my posts invisible? lol Ph1 and ph3 doors - Matt - 11-01-2012 Right so the gap for rub strips are different sizes :/ but hinges are the same Re: Ph1 and ph3 doors - Connor - 11-01-2012 No... the door are EXACTLY the same, EXCEPT from the mounting points for the door cards Ph1 and ph3 doors - Matt - 11-01-2012 Okay thats awesome, cheers guys. Just take me a little longer to get as I'm thick haha Re: Ph1 and ph3 doors - ginge191 - 11-01-2012 Connor Wrote:No... the door are EXACTLY the same, EXCEPT from the mounting points for the door cards Ok, im going to get a picture of this tomorow and show you the differnce in sizes of my rubstrips on the OUTSIDE of my car.... Re: Ph1 and ph3 doors - Connor - 12-01-2012 Omg ginge... I know the rub strips are different, but the holes you push them into are the same... Re: Ph1 and ph3 doors - ginge191 - 12-01-2012 ginge191 Wrote:arn't the rub strips width different dependent on the model - i know between my 1.4 and dturbo they were different... Im talking about the ACTUAL strips - as i said in my first post - THE WIDTHS CAN BE DIFFERENT ... (as in the width of the ACTUAL strips) So when he's looking for a new door, if he needs the same width to be aware of this... and a picture to tell you what i was on about..
Re: Ph1 and ph3 doors - Connor - 12-01-2012 No ginge, he just has to take the rub strip off his current door and fit to the new door... THE HOLES ARE THE SAME... I never said the rub strips are the same... |
