Top end rebuild - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Top end rebuild (/showthread.php?tid=835) |
Top end rebuild - Niall - 10-01-2012 Ok so for my summer project, I'm going to do a bit of work on the spare head I have for my 1.8. Old mans going to give me a hand with it seeing as he used to do this sort of work for jaguars. With the head off, this is a perfect opportunity to do all the shitty jobs as well as refurb the head. Im trying to get a list together of what I need really. I've got on there all the simple things like cambelt kit, top end gasket set, new valves for the new head etc etc but what else should I look at doing? Cheers guys! Re: Top end rebuild - Connor - 10-01-2012 Why did your dad molest jaguars? What did they do to him? Re: Top end rebuild - Niall - 10-01-2012 Connor Wrote:Why did your dad molest jaguars? What did they do to him? Wouldn't you if they let you? Personally I don't see any problem with animal molestation providing you ask permission first...... Re: Top end rebuild - Foxy-jim - 10-01-2012 Port polish? Re: Top end rebuild - Niall - 10-01-2012 Foxy-jim Wrote:Port polish? Getting done. Grinding out the ports as well as they are very restrictive on the 1.8 head. Re: Top end rebuild - Eeyore - 10-01-2012 i dont know much about engine internals but can you not get fast road cams and fit them at the same time? Re: Top end rebuild - Niall - 10-01-2012 SRowell Wrote:i dont know much about engine internals but can you not get fast road cams and fit them at the same time? Requires a remap which on the 1.8, requires a new ECU as apparently the Sagem ECUs are shite to remap! Re: Top end rebuild - Scott - 10-01-2012 While you've got the head off take the rest of it out and fit a 6 engine ![]() Re: Top end rebuild - Niall - 10-01-2012 Scott Wrote:While you've got the head off take the rest of it out and fit a 6 engine FYC..... That would be too easy! Re: Top end rebuild - Foxy-jim - 10-01-2012 There are different types of cams, and some of them you can run without a remap! Re: Top end rebuild - Scott - 10-01-2012 And also much more win ![]() ![]() While I'm here, inb4 'lol u mean diesel' Re: Top end rebuild - Niall - 10-01-2012 Oi it's got a good engine in thank you! Just because we're not all driving v6s....especially broken ones!! Tbh even without a remap, they normally run pretty crap. Fitting cams isn't the most difficult job so if I can ever afford a new ecu, might get some fast road cams Re: Top end rebuild - Scott - 10-01-2012 Your couch! My V6 is like sex panther, it's illegal in 9 countries, and 60% of the time, it works everytime. Re: Top end rebuild - Niall - 10-01-2012 Clearly Scott it isn't as good as the 306. And I'm also disapointed as you own a 306 owners club yet you clearly don't live for the 306! Shame on you! Top end rebuild - Matt - 10-01-2012 I'm thinking. Of doing this too. Buying a spare head soon ![]() ![]() Re: Top end rebuild - Foxy-jim - 10-01-2012 They run ok without a map! They may cut out occasionally but will be fine! Just dont go for the flat out rally cams just get fast road ones! Re: Top end rebuild - Niall - 10-01-2012 Iirc the head is very similar to the gti one but the 1.8 ports are triangular! I reckon if they were ground out it would give a fair bit more power. Might look into a new ecu towards the end of the year. If I get that then cams are a big possibility. Re: Top end rebuild - Foxy-jim - 10-01-2012 Good man! May aswell put throttle bodies on too then and save money on mapping it twice! Re: Top end rebuild - Niall - 10-01-2012 Nah don't want the stupidly loud noise. It would sound porn but would be impractical for me.....says the guy who's now got a stupid loud exhaust Re: Top end rebuild - Foxy-jim - 10-01-2012 I cant wait to cam and throttle body mine!!! Re: Top end rebuild - Niall - 10-01-2012 Yeah easier for you. You need one less can than me lol Re: Top end rebuild - Foxy-jim - 10-01-2012 Very true! Re: Top end rebuild - mjcook1984 - 11-01-2012 would an xsi head be a straight fit but with better flow as its less restrictive than the standard xs head ports must be very similar as they use the same inlet manifold Re: Top end rebuild - Foxy-jim - 11-01-2012 Or even better could you put a gti head on it? Re: Top end rebuild - Niall - 11-01-2012 Nope xsi head has a 86mm bore and the XS is 83mm. I'm not 100% sure what the ports are like on the xsi but i do know there is a lot of room for improvement with the XS head. Re: Top end rebuild - Niall - 11-01-2012 Foxy-jim Wrote:Or even better could you put a gti head on it? Same problem as the xsi head mate. Re: Top end rebuild - Foxy-jim - 11-01-2012 Fair enough mate! I have the same problem with the bore if 1.6 heads being too big! Re: Top end rebuild - Midnightclub - 11-01-2012 Foxy-jim Wrote:Fair enough mate! I have the same problem with the bore if 1.6 heads being too big! Pretty certain you can use the rallye head from the 1.3 though ![]() Re: Top end rebuild - Foxy-jim - 11-01-2012 Already looked into this and it will be a pain in the arse as all the sensors need to be changed and I wont be able to use my ecu as its a 3-plug not a 1-plug. Re: Top end rebuild - Dum-Dum - 11-01-2012 Get new valve guides pressed in and use new valve stem oil seals while your at it. Maybe slightly larger inlet valves if your going for power. |
