Help... - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Help... (/showthread.php?tid=8270) |
Help... - Bananalad - 23-11-2012 Need to drain the water out of my 306 tonight as i have no antifreeze and there expecting -4 degrees weather.. Whats the easiest way to drain the block? Thanks RE: Help... - Bananalad - 23-11-2012 Dont think draining the radiator would be good enough would it? As there would still be water in the block.. Freezing very hard outside now! RE: Help... - karl1989 - 23-11-2012 take the bottom pipe of. wont get it all out but if you run anti-freeze through it should be ok RE: Help... - Matt - 23-11-2012 There is a drain hole on the rad open that and let it pour out, then when it seems fully drained, blow into the filler neck make sure you get a good seal though so all the air pushed the water out. Replace bung, an fill RE: Help... - Bananalad - 24-11-2012 Got antifreeze today, how much water do one of these hold so i know what ratio to mix it? Thanks RE: Help... - Bananalad - 24-11-2012 Actually i dont need to mix it, 9 liters do it?? RE: Help... - Tom - 24-11-2012 (24-11-2012, 12:05 PM)Bananalad Wrote: Actually i dont need to mix it, 9 liters do it?? 9 litres!? You changing the antifreeze on your lorry lol? RE: Help... - WiNgNuTz - 24-11-2012 (24-11-2012, 12:58 PM)Tom Wrote:(24-11-2012, 12:05 PM)Bananalad Wrote: Actually i dont need to mix it, 9 liters do it?? 9 litres should be MORE than enough! RE: Help... - Bananalad - 25-11-2012 I have no idea how much coolant one of these hold Quick google search and the first number i seen was 9 RE: Help... - Choppin - 25-11-2012 Don't no if this helps but my hdi was just over 7 litres RE: Help... - Bananalad - 27-11-2012 If anyone is wondering in future the xud takes 7 and a half litres so i wasnt too far off with 9 |
