what does a p00c8 and p00cc code mean? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: what does a p00c8 and p00cc code mean? (/showthread.php?tid=8086) |
what does a p00c8 and p00cc code mean? - scfc_151 - 18-11-2012 Its on a 306 hdi and I used an elm 327 with pcmscan I unplugged the egr and cleared the code for that which was also on there thanks cheers RE: what does a p00c8 and p00cc code mean? - cully - 18-11-2012 p00c8 = P00200 = Injector Circuit Malfunction p00cc = P00204 = Injector Circuit Malfunction - Cylinder 4 S2000PM1/2 - Injector control # 4. Open circuit or short to earth. P02XX = Fuel and Air Metering if you get letters in the obd codes it normaly needs converting to Decimal as its in Hexadecimal RE: what does a p00c8 and p00cc code mean? - Strikeforce - 18-11-2012 (18-11-2012, 02:33 PM)cully Wrote: p00c8 = P00200 = Injector Circuit Malfunction What is the exact problem with the code p00c8/p00200, i know it means injector circuit malfunction but what is that exactly is the prob and how do you fix it? RE: what does a p00c8 and p00cc code mean? - Poodle - 19-11-2012 That seems a pretty specific code, so i'm thinking wiring problems on injector 4 lol. It's not a problem i've seen before, but have a look about for burnt contacts, corrosion and broken wires, could even just be a bad earth. |
