Door adjustment - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Door adjustment (/showthread.php?tid=8025) |
Door adjustment - Willo - 16-11-2012 Can I adjust my drivers door sits high at the back near the rear door and as just found out at the car wash leaks like a sieve RE: Door adjustment - Matt - 16-11-2012 Loosen of the bolts on the hinge and rearrge with a jack underneath ![]() RE: Door adjustment - Willo - 16-11-2012 Cool wasn't sure if there was a different was on one of these thanks RE: Door adjustment - Matt - 16-11-2012 Just make sure you support it, they can be a bitch to line up so make sure you do it in small amounts loosen a little so you can control the movement rather than the whole lot dropping RE: Door adjustment - kernow_joe - 16-11-2012 a jack you say? hmm never needed a jack adjusting mine, just loosen enough to allow a little movement, not enough that it flaps about though, then you can easily adjust a small amount without it moving back/wrong way RE: Door adjustment - Matt - 16-11-2012 I use a jack just incase, I know what I'm like, I would lossen it too much, loose the original line up and never get it right haha RE: Door adjustment - kernow_joe - 16-11-2012 haha do always be careful on first close of the door after adjustment, I nearly forgot and slammed my door, it wasn't very lined up!! would have dented the shit out of the roof RE: Door adjustment - Willo - 16-11-2012 This is the gap I'm on about ![]() |
