HDI injectors? - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: HDI injectors? (/showthread.php?tid=7820)
HDI injectors? - Eeyore - 09-11-2012
Yo!
Injectors are apparently noisy on my hdi! So what am i looking for here? Is it just replacing the seals (copper rings?) or is it much more likely that the injectors themselves or one of them at least arent working properly?
Hopefully ill be getting some injectors dead cheap anyway but in case the sale falls through... there are no 306s in my local scrappers but there are lots and lots of 406s!
Now i know that some of the 406s had the 2.0 hdi engine in so those injectors are compatible but what about the other 406 diesels such as the 2.2 HDI and the NA?
Also if i take the injectors out will i need to put them back in with new seals or can you get away with taking them out a few times?
Thanks
Sam
RE: HDI injectors? - Toms306 - 09-11-2012
It's the injectors themselves that tick Sam.
Cully replaced his with some low milage ones from a 307 iirc.
RE: HDI injectors? - cully - 09-11-2012
injectors
from any dw10 will fit
always fit the same numbers as a set
ie. replace one with the same number but you could change all 4 to a different number
always renew the copper washers pug partnumber 198196
plastic guide rings can be reused if not broken
torque settings for
injector clamp 30Nm
fuel pipe unions 20Nm
numbers to look for
0445 110 008
0445 110 044
0445 110 062
0445 110 076
076 being the newest version
and where to find them
[Image: boschhdiinjectorslist.jpg]
RE: HDI injectors? - Eeyore - 09-11-2012
well thats that answered! Knew youd be along soon cully Wink thanks guys!
