What Temperature? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: What Temperature? (/showthread.php?tid=7690) |
What Temperature? - bigcheez2k3 - 05-11-2012 What temperature should a dt sit at? Now it's got colder mine is hovering just over the 70 on the guage, whereas when it was hot in august/september (can't remember exactly when) it kept sitting at 90 all the time then putting the fans on in traffic. Not sure if something has broken as I'm sure last year it was between 75-80 around this time of year and I know it didn't get that hot last summer. What Temperature? - Frosty - 05-11-2012 Usually about 80 I think mine is RE: What Temperature? - Toms306 - 05-11-2012 Thermostat may be stuck open so it never warms up properly. However I wouldn't worry about it tbh, the HDi seems to sit at 75c all the time too. RE: What Temperature? - THE_Liam - 05-11-2012 Sounds like thermostat, mine's doing the same. Like £5.50 with club discount from ECP
RE: What Temperature? - Jake949 - 05-11-2012 mine just sits at 70 no matter what the weather? even in the summer RE: What Temperature? - Dum-Dum - 06-11-2012 Mine sits below 80 It could be the temp sensor going gradually also though RE: What Temperature? - JackLewis_Dturbo - 06-11-2012 mine sits at 85 if im moving and if im sat still for ages it will creep to 90 then fans kick in. this is normal... RE: What Temperature? - Kwik - 06-11-2012 mine sits at 75-80 when moving and up to 90 when sat i traffic. i have a new aliminium rad. the low speed fans kick in at 97c and high speed at 107c so all peoples who kick in lower your temp gauge is out RE: What Temperature? - Pugmarshall - 09-11-2012 Same here, new-ish rad and sat at 84ish in the summer or 90 in traffic, now its gone cold it sits at about 79 degs and 83/84 in traffic? RE: What Temperature? - londondan86 - 09-11-2012 My thermostat is fooked so it barely gets to 70! New stat getting fitted over the w/e I think. They should sit around the 80 mark when moving. RE: What Temperature? - Oil-burner - 09-11-2012 Think it's ment to be about 84degrees in a dt iirc RE: What Temperature? - Kwik - 09-11-2012 75 to 80 when moving if your on a tmic running quite a hard stage 1 on a bosch the engine temp will get hotter while booting it but will go back down when you go back to normal driving. that's going off my dt's past and present. RE: What Temperature? - 4WayDiablo - 10-11-2012 Mine sits at just above 70 but my other one sits around 80 and easily goes to 90 (but will never go past that) RE: What Temperature? - David - 10-11-2012 Mine runs between 80-90 |
