4x100 borbet T's - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: 4x100 borbet T's (/showthread.php?tid=7632) |
4x100 borbet T's - Jukie88 - 03-11-2012 I'm picking up a set Sunday only issue is the centre bore and et, the et is 35 will it fit in the arch also is the centre bore gunna fit ?? As its a wheel if a vw :-( didn't really think about it b4 I bought them RE: 4x100 borbet T's - Scott - 03-11-2012 Centre bore will be wrong, not to mention that it's the wrong PCD. You'll need adapters if you want to fit these. 4x100 borbet T's - Jukie88 - 03-11-2012 Was looking at 4x108 to 4x100 stud conversion kit will this have the changed centre bore aswell ?? RE: 4x100 borbet T's - Scott - 03-11-2012 I'm not sure to be honest...you'd be better off checking on the website/with the seller
4x100 borbet T's - Jukie88 - 03-11-2012 Cool beans I knew the stud pattern was different but these wheels are shit hot and I want them on the car do you know off the top of you're head what the centre bore is on a 306 ?? RE: 4x100 borbet T's - C.A.R. - 03-11-2012 Centre bore is wrong, stud pattern is wrong, offset is wrong. You're in for a great getting these to fit! PCD; 108 ET13-18 Bore; 65.1mm RE: 4x100 borbet T's - Chris - 03-11-2012 Custom adapters, be around 200, or you can buy 4*108 to 4*100 adapters off ebay for around 120 but there 20mm and renault centre bore wheel side. RE: 4x100 borbet T's - Seid' - 24-11-2012 make re-drill, is much better 4x100 borbet T's - Jake - 24-11-2012 For the price you are going to pay to make them fit, added onto the price of the wheels, much nicer wheels are available. Sell on IMO. |
