Fitting injectors hdi - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Guides (https://www.306oc.co.uk/forum/forumdisplay.php?fid=9) +--- Thread: Fitting injectors hdi (/showthread.php?tid=7505) |
Fitting injectors hdi - Jukie88 - 29-10-2012 Can I use the parts I take off to put new Injectors back on ??? RE: Fitting injectors hdi - cully - 29-10-2012 i would use new copper washers peugeot part number 198196 around £7 for 4 the plastic guides are reusable if not broken, and i have reused the hp pipes and leakoff plugs nd lines Fitting injectors hdi - Jukie88 - 29-10-2012 Thanks was gunna do it tomoz but I'll order those copper rings :-) RE: Fitting injectors hdi - gareth7 - 30-10-2012 Make sure you keep everything nice and clean when you change them mate and look inside the head and make sure there's no dirt where the injectors seat themselves on the washers otherwise they may not seal properly. Fitting injectors hdi - Jukie88 - 30-10-2012 Ok pal wil do RE: Fitting injectors hdi - Arron - 18-09-2013 So wheres the guide!? I just want an idea really as it looks fairly self explanatory but pics and potential common hiccups along the way would be nice. I see I need some seals.... RE: Fitting injectors hdi - Poodle - 18-09-2013 Mostly covered above tbh, really is simple. Main potential issue is getting shit in the fuel system, keep it all clean and plug holes as they appear. Otherwise its just injectors getting stuck in the head, but cross that bridge if you come to it. The link in my sig should have a bit about removing injectors, unless thats another bit I havent uploaded yet lol. RE: Fitting injectors hdi - Arron - 18-09-2013 Cheers. Me and karl will be doing this friday. Il try and take pics as I go along. Do you think peugeot will have them washers in stock... surely they are a generic part and wont need to special order from france!!! RE: Fitting injectors hdi - rd070707 - 18-09-2013 I got the washers on eBay, genuine pug items RE: Fitting injectors hdi - Arron - 18-09-2013 Their going in thursday evening so ive only tomorrow before 12 to get old of some. Citroen are down road from me so im going to try there first |
