exhaust housing - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: exhaust housing (/showthread.php?tid=7405) |
exhaust housing - Ricky - 27-10-2012 I think I already know the answer to this, probably a stupid question.. I have a TD04HL which I think had a bit too much lag for my liking because of the bigger turbine wheel, if I bought another TD04 with the smaller turbine wheel, can I use the exhaust housing from my HL or would it not work properly? RE: exhaust housing - Ricky - 27-10-2012 Anyone? RE: exhaust housing - Ricky - 27-10-2012 Someone must know. RE: exhaust housing - Chris - 27-10-2012 No unfortunatly not. As I understand you want to run a smaller turbine wheel in the same housing? RE: exhaust housing - Ricky - 27-10-2012 Yeah, thought not. Cheers. Will put up with it for now until I sort another turbo. |
