brakes - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: brakes (/showthread.php?tid=6809) |
brakes - connor306 - 07-10-2012 I don't spose someone can help me cb they my brakes have serious play in them and I'm not sure why there's fluid in them I don't think there's any air in the lines and when I start the car the brake master cylinder doesn't firm them.up if that makes any sence Please help lol RE: brakes - strictly_perv - 07-10-2012 Hard to work out what you mean from the description but have you checked the vacuum is connect/sealed? RE: brakes - connor306 - 07-10-2012 No I haven't checked that mite just b me being silly il try bleeding them first then go from there cheers bud RE: brakes - Ed Doe - 07-10-2012 Play in something usually means it travels/moves out of its normal operational travel. Do you have a soft pedal? Is your braking force naff all? If so you don't probably have an air bubble in your lines or calipers. |
