6 speed box and reverse cable - Printable Version
+--- Forum: Parts (https://www.306oc.co.uk/forum/forumdisplay.php?fid=25)
+--- Thread: 6 speed box and reverse cable (/showthread.php?tid=6769)
6 speed box and reverse cable - C2K - 06-10-2012
Have a gearbox removed from my own rallye, complete with the reverse selector cable. No crunching gears or noises from the box.
75 collected from Peterborough. Smile pic to follow later on.
RE: 6 speed box and reverse cable - Pugmarshall - 06-10-2012
Damn it so far! How much would postage be?
RE: 6 speed box and reverse cable - C2K - 06-10-2012
Don't know to be honest, I can but have a look! I would imagine at least £20!!
I am In Coventry tomorrow night if you want to meet me? That's about the closest I can get to you!
RE: 6 speed box and reverse cable - darrenjlobb - 06-10-2012
Is it silent on idle with foot off the clutch? (ie any input shaft noise)
Darren,
It's been off the car since I went to South Africa 18 months ago, but I don't recall any issues with it whatsoever. I have fitted a VTS box purely because i preferred the ratios and wanted the full lock. Smile
Postage is coming out at 16+VAT with interparcel on a guesstimate size and true weight so should be ok to courier but worried it would get damaged!
RE: 6 speed box and reverse cable - C2K - 08-10-2012
BumpSmile
RE: 6 speed box and reverse cable - C2K - 16-10-2012
Bump. Pic attached below, I forgot to do it before. Not the best, but it's in the corner of the garage like.. Think I bent the fork arm up to aid removal as the pin wasn't playing ball.
[Image: IMAG0335.jpg]
That's a Rover Cat if you want it ;P
RE: 6 speed box and reverse cable - HDIkyle - 16-10-2012
I posted one before in a plastic supermarket tray with some ducttape to secure it and no issues. Cannot say cost tho as it was paid for by the buyer
RE: 6 speed box and reverse cable - Dangti6 - 17-10-2012
(06-10-2012, 06:24 PM)C2K Wrote: Postage is coming out at 16+VAT with interparcel on a guesstimate size and true weight so should be ok to courier but worried it would get damaged!
What sizing did you enter to get that very reasonable price?
When I've sent a few in the past they were 40/42kg I think.
RE: 6 speed box and reverse cable - C2K - 17-10-2012
Hi Dan,
Can't remember, think i guessed at 36kg as I remember sending a Rover gearbox through that before. Smile
RE: 6 speed box and reverse cable - C2K - 18-10-2012
Bump, lots of interest but no takers.
