Rad Fans stuck on :( - Printable Version
+--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23)
+--- Thread: Rad Fans stuck on :( (/showthread.php?tid=6617)
Rad Fans stuck on :( - Tom - 01-10-2012
Every time i switch the ignition on the rad fans come on... This is after a done a coolant flush and bled the system. Worked fine before (why cant i just leave stuff alone).. Darren suggested unplugging and plugging in the sensor a few times and i tried that and it still just comes on and off with the ignition.. What the f*ck have i done lol
RE: Rad Fans stuck on :( - MissTap_GTI6 - 01-10-2012
Hi Tom,
Ginge had to re-wire the plug as it corroded. It was never soldered; only a temp fix. Check that.
You may need to re-solder it.
Smile
RE: Rad Fans stuck on :( - C2K - 01-10-2012
I'd also check the fan loom, to the right hand side of the radiator on the fan cowling, where the body loom meets the fan loom. My fans ran themselves when this was corroded.
RE: Rad Fans stuck on :( - ginge191 - 01-10-2012
hey mate; yeh, as Eli says; i had to get a new plug from the scrappy and re wired it in, only connected with spade connectors as i had no soldering equipment. Have a check to see if it's come un done/tape come off etc... If not, follow the cable and sensors to make sure they're all intact etc.
RE: Rad Fans stuck on :( - Tom - 01-10-2012
Tommorrow.
Step 1: Check connections
Step 2: Get shitty
RE: Rad Fans stuck on :( - Eeyore - 02-10-2012
mine dont work at all so be glad yours do! D:
RE: Rad Fans stuck on :( - ginge191 - 02-10-2012
Alternatively mate; just wire in a manual switch for the fans rather than sourcing the problem all together!
RE: Rad Fans stuck on :( - strictly_perv - 02-10-2012
^ That's what I've done to my slimline fan, all you need is some wire, switch and a relay.
yeh i might just go for two slimlines just to get them working again D: and of course save weight!
RE: Rad Fans stuck on :( - Tom - 02-10-2012
The fans are constantly on and off so i really want to get them working magically again :p
RE: Rad Fans stuck on :( - Tom - 03-10-2012
So it seems only one fan is on constantly (with ignition) and the other kicks in after i've been sitting for a while :/ But earlier i got out the car and one of them stayed on for a few seconds after i had took the key out! WTF
RE: Rad Fans stuck on :( - C2K - 06-10-2012
As per my post. Mine ran itself all night doing this.
Has the potential to cause fires so you might want to check sooner rather than later whether this is your cause.
RE: Rad Fans stuck on :( - Tom - 06-10-2012
I've just unplugged them for now, hasnt been any decent wether for me to take it apart and have a look so im just keeping my eye on the temperature gauge.
