LDA pin mod - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: LDA pin mod (/showthread.php?tid=5351) |
LDA pin mod - 306 d turbo - 05-08-2012 I am currently running a Bosch Pump and i am looking for a bit more power. Will rotating the LDA pin Give a bit more power? Does the pin have to come off the diaphram to rotate it or can the diaphram with the pin on it be rotated as one unit? RE: LDA pin mod - 4WayDiablo - 05-08-2012 Dan! Used to grind the back like a boss.... He then fell off his push bike You may get lucky and he may start doing it again. He only charged about a fiver plus your LDA in return RE: LDA pin mod - Dave - 06-08-2012 Dude there's a guide that's been stickies about this!! RE: LDA pin mod - kernow_joe - 06-08-2012 if rotated correctly, do some reading and take bits apart, the lda is pretty simple to understand, more pin movement means more fuel RE: LDA pin mod - karl1989 - 06-08-2012 ive been told to do something with my diaphram but been told my pump doesnt have one RE: LDA pin mod - Dan! - 06-08-2012 This should answer most questions about the LDA system. If you have any other questions about it feel free to ask in there and then the answer/info can be added to the guide ![]() http://306oc.co.uk/forum/thread-131.html |
